Cougargm's avatar
Cougargm
Fridge issue
We overloaded our generator and while the genny was running, nothing was working. Simply hit the reset and everything worked- except the fridge & furnace. Found a blown fuse, replaced it and the furnace worked fine. Unfortunately the fridge still isn't working. Unplugged it for awhile, hoping it would start once plugged in again, but nothing. It won't turn on at all, so I can't even pick LP mode let alone electric. Any suggestions as to what I should try or look for next? THanks in advance!
  • I only found one GFI in the RV and that was in the bathroom. Reset that but it didn't help.
  • It's a Norcold. The Class C is 15 yrs old and I believe the fridge is as well. (not original owner). I haven't checked the voltage but it won't power on at all, as I can't even select LP or AC for the mode.
  • Make and model of the fridge might help us help you better. Are you getting 12 volts at the fridge?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
