Old-Biscuit
Aug 19, 2015Explorer III
campn4walleye wrote:
OB, we have that baffle installed. It's attached to the inside of the access panel. Everything you've said makes sense. We have a flue baffle as well. We'll clean it again to insure no blockage.
The warranty work appears to have been done? We just don't understand why the fuse issue still occurs.
This is becoming an issue to solve just because we're like a bulldog with these issues. We want to fix it ourselves.
How did you get your knowledge of such things? Thank you for your assistance. You always offer solutions...and they're great.
Can you take pictures and post them
Air baffle on inside of cover
Flue baffle around burner
Picture of location of thermalfuse
Only four things that would cause that thermalfuse to blow.
*Blockage in cooling unit causing overheating issue
*Flame too high......high gas pressure and flame going up inside flue
*Obstruction in flue....flue baffle falling down/top opening in flue covered
*Flame too high from excess air...lean flame (air rich)
First three...would be an issue whether stationary or in transit
