dougrainer
Aug 20, 2015Nomad
AnEv942 wrote:
This was the recall add-on? Simular to this? (Outer baffle removed)
The thermo fuse link at the bottom of burner?
Yes, WHICH thermo is blowing? The one on the burner flue cover or the one behind the burner on the back bottom wall of the refer. The bottom thermo is a FLAME burned thermo, NOT heat. So, if in transit, the LP flame is being blown downward and backward, that would melt/burn that thermo fuse. I call the one on the burner flue cover a SNAP DISC thermo. Doug
