Old-Biscuit
Oct 08, 2016Explorer III
Beverley&Ken wrote:
In the fridge portion, at back are the fins and under the fins, there is a trough to collect condensation. There is a small tube from this trough to outside to drain the condensation. Any small amount of dirt will plug the tube and the condensation will then drip inside the fridge. Just clean out the tube.
Ken
Open lower outside access vent cover
Inside there is a tube that comes from that drip pan into a drain cup next to burner area.
Condensate drains into cup...warm burner area evaporates condensation in cup
Your fridge also goes thru a 'defrost cycle' every 48-52 hrs.
Fridge shutdowns allowing temps to rise then restarts cooling cycle
If FINS in food compartment are frosty then they will drip allot of water during this cycle
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
