coolmom42's avatar
coolmom42
Explorer II
Oct 25, 2020
fridge level?
I searched and didn't find an answer...
My Class C is parked in my yard, waiting for the concrete guy to pour a pad. It's level front to back, but about 3 degree slope side to side of the RV. This means that the refrigerator is level left to right, as you stand looking at it, and off from front to back. I know the coil basically zig zags left to right, but it won't be vertically plumb.
Is it OK to run the fridge in this situation? I just need to cool it down before a trip.
  • pianotuna wrote:
    I'd do a bit of leveling.
    X2. As mentioned above, a couple of boards should get you less than 2 degrees which is recommended.
  • If sure of degree out of level, probably okay. but it can't be too hard to just put a couple boards down on the low side, to remove any concern. It should be easy to move a C ahead/back a little, if in running condition to take a trip soon.
    Jerry
  • Up to three degrees side to side and up to six degrees front to back is fine with newer Norcold RV fridges.
Having RV issues? Connect with others who have been in your shoes.24,237 PostsLatest Activity: Apr 23, 2025
