BFL13
Feb 01, 2019Explorer II
DrewE wrote:BFL13 wrote:
On my Dometic S630, the door switch goes to the top blade on the power supply board J1 (orange) and the light goes to the next one down J2 (yellow). Perhaps the wires are loose on the blades. I had that with one of the connections on mine, only it was for the heater.
Unfortunately that's not the case on my fridge. The switch and light socket are wired in series directly at the door. The switch is in my opinion not the greatest design and tends to get a bit of corrosion or crud internally from the dampness etc. and fails to make good contact. I've taken it apart and cleaned it, which helped for a time, and may do the same again...or pony up for an expensive replacement switch, or kludge together some other switch arrangement (a magnetic reed switch, perhaps with a transistor or relay for increased power handling, is one appealing option).
It still must get its 12v from the power supply board at the back though? Mine has +12 wire going from J1 to door switch, then to lamp, then back to J2. The board has -12 from J4 to the chassis bonding terminal block at the back where the fridge-battery wires go to.
The board has a feature I didn't know about before I had the recent heater problem-- an on off switch on the side they say is for "storage" that lets you kill power to the fridge light so you can leave the fridge door open when the RV is not in use, so the fridge does not get smelly.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
