stevemorris's avatar
stevemorris
Fridge, new house fridge vs rebuild old rv fridge
our 15 yr old dometic is working reasonably well, but thinking ahead!!
rebuild it or replace it with an inexpensive house fridge which of course is 120 vac only. rv fridge is in great shape cosmetically
we very rarely dry camp, maybe 1 night at a walmart once in a while
running a 120 volt fridge off an inverter is probably not an option, we only have one "normal sized" rv battery and really don't want to expand on that
so really two issues, running the fridge on the road and when dry camping.
thoughts/opinions?
  • BFL13 wrote:
    On my Dometic S630, the door switch goes to the top blade on the power supply board J1 (orange) and the light goes to the next one down J2 (yellow). Perhaps the wires are loose on the blades. I had that with one of the connections on mine, only it was for the heater.
    Unfortunately that's not the case on my fridge. The switch and light socket are wired in series directly at the door. The switch is in my opinion not the greatest design and tends to get a bit of corrosion or crud internally from the dampness etc. and fails to make good contact. I've taken it apart and cleaned it, which helped for a time, and may do the same again...or pony up for an expensive replacement switch, or kludge together some other switch arrangement (a magnetic reed switch, perhaps with a transistor or relay for increased power handling, is one appealing option).
  • Those older Dometics seem to be better built and may last forever. Personally, I would not touch it.
    But if you want to go to electric, there are kits for converting what you have to an AAC or DC compressor based system from JC Refrideration that work great.
    It still must get its 12v from the power supply board at the back though? Mine has +12 wire going from J1 to door switch, then to lamp, then back to J2. The board has -12 from J4 to the chassis bonding terminal block at the back where the fridge-battery wires go to.
    The board has a feature I didn't know about before I had the recent heater problem-- an on off switch on the side they say is for "storage" that lets you kill power to the fridge light so you can leave the fridge door open when the RV is not in use, so the fridge does not get smelly.
    It does get 12V power from the board or somewhere, and that power is consistently reliable to the light. I don't know if there's a switch on the board to kill the light during storage; it would make sense if there was, as the light is otherwise on even if the fridge is not turned on (and indeed I've added a separate toggle switch to allow the light to be turned off without having to remove the bulb, which may have been unnecessary extra work).
    At any rate, I am perfectly fine with my fridge; it keeps things cold when it should, and has given no hassle at all that hasn't been obvious operator error, such as forgetting to turn it back on after turning it off temporarily for one reason or another.
  • midnightsadie wrote:
    it ain,t broke ,I,d leave it alone.
    X2
    Don't waste your time rebuilding either.IMHO
  • We replaced our Dometic RM1350 with a Samsung RF18. We got tired of it being OK. We wanted frozen food and hard ice cream in the freezer. We do as the OP. No dry except a couple nights on a cross country trek to the family. We do this with a RV750ULHW inverter/charger and 2 Trojan105. Fridge stays cold and freezer frozen for over 8 hours, without shore hookup. The batts stay charged while driving. If needed, we could run the gennie for a couple hours. It works.
    Expensive!!!
    https://www.amazon.ca/s/?ie=UTF8&keywords=rv750ulhw&tag=googcana-20&index=aps&hvadid=267156749726&hvpos=1t1&hvnetw=g&hvrand=10786131799623229670&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9001606&hvtargid=kwd-301480162229&ref=pd_sl_67ib6guyk3_e
    thoughts/opinions?
    Well, given your constraints of one battery and no inverter, your options will be to rebuild/replace the existing fridge, or use a residential and keep it off/closed when travelling and hope it stays cool enough. Could always supplement with a cooler when you know you'll be overnighting in a hot area.
    You could hook up a 400w or so inverter to your one battery and hope the truck charging system keeps up with the demand while driving, but that doesn't help you overnight.
    No matter which option you take, I'd run it till it quits first. No point in replacing a fridge that may just last another 10 years...
  • BFL13 wrote:
    Expensive!!!
    Not sure I understand. Question!!! If the reference is to buying an RV750ulHW then, we did not. It came with our Allegro 36LA. For an install for just a RR, then yes there are other choices. BTW, I did not catch that the OP had no inverter. Sorry.
  • The money you save by buying a residential unit will allow you to buy more batteries.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
