donn0128
Jan 22, 2018Explorer II
Batteries had to be charged with a manual charger? Something is wrong there. IF you have 120VAC at the RV and IF the salesman switch is turned on, then you have other problems. All dual fuel absorbition refers require 12VDC for control voltage and either 120VAC or propane for cooling power. You apparently are missing 120VAC at the refer.
