dblack440
May 03, 2017Explorer
Wild Card wrote:
Its obviously loosing power to heating element. New boards can be bad.
That was my thought as well but if I remember correctly even after it quits cooling there is still power to the element....I will have to double check that. I was told that on propane it only has one set temp ( not sure if that's true) but if it is I'm thinking that the thermistor might actually be bad and after it runs for the 14-16 hours that it's not sensing correctly and no longer calls for cooling?? Is that a possibility? If so that might explain why it only has the issue on AC....I've been all over the net and haven't found anyone who has had quite the same symptoms as I have..Very frustrating.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
