dblack440
May 19, 2017Explorer
And the saga continues...odd that nobody has ever had quite the symptoms that I have...So the latest development is that when I wired the element direct to 120 with the fridge off both compartments cooled down to 0 degrees after 18 hours...so the cooling system definitely is not my issue nor the element it's self. After that I let the fridge warm back up to 50 degrees, plugged the element back into the board and turned the fridge back on to 120...It cooled back down to 34 degrees and stayed working perfect for 5 days straight.At this point I was baffled but excited since it hadn't worked this long on 120 since the problem developed and the only thing I could rationalize is that by running the fridge wide open with the element wired direct that maybe it had freed some kind of blockage..Which still didn't make sense being how it always works perfect and endlessly on Lp..However on day 5 the fridge began to heat back up and was over 50 degrees once again and the freezer had defrosted...so once again I'm back to square one..Any other thoughts or suggestions would be greatly appreciated! Extremely frustrated at this point!!
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
