dblack440
May 19, 2017Explorer
It's not in a slide room, I haven't tried moving it to the next element sleeve ( didn't know it had more then one) I installed it in the same one when I replaced it (same wattage, 325 that the old one was) and the element was the first thing I changed when it started this almost a year ago, and my old one actually still tested good...Just went with what the RV tech told me was likely wrong.. Nothing I have done including the new board ever changed the symptoms. And I haven't checked amps. As far as the fan, that was the one thing I noticed. The fan would just run hours once it quit cooling and would only shut off if I shut the fridge off.. Hope that helps
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
