dougrainer
May 19, 2017Nomad
dblack440 wrote:
It's not in a slide room, I haven't tried moving it to the next element sleeve ( didn't know it had more then one) I installed it in the same one when I replaced it (same wattage, 325 that the old one was) and the element was the first thing I changed when it started this almost a year ago, and my old one actually still tested good...Just went with what the RV tech told me was likely wrong.. Nothing I have done including the new board ever changed the symptoms. And I haven't checked amps. As far as the fan, that was the one thing I noticed. The fan would just run hours once it quit cooling and would only shut off if I shut the fridge off.. Hope that helps
This is what I told you on 5/2/2017:B Doug
"If it works on LP but does NOT on 120, the Thermister is NOT your problem. The Thermister dose the same thing regardless of power source. It could be LOW 120 power supply or the tube the heating element is installed in is not secure to the burner flue. I would try the other heating element sleeve. Dometic's have 2 heating element sleeves." Doug
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
