dougrainer
May 20, 2017Nomad
dblack440 wrote:
I'm showing I believe it was 121.4 Volts coming into the board. I'm going to pull the fridge back out this weekend and check the flue and I'll try it in the other sleeve. I just put the new one in exactly as the old one was.. So what's your theory Doug as to why that would allow it to cool for my usual 14-16 hour period and most recently nearly 5 day period before it decides to quit cooling again? I'm just trying to rationalize this.
Have no clue. But, the reason for the swap of sleeve is to remove the possibility the original sleeve is not welded/secure to the burner flue tube. Getting hot, it may be slightly separating and NOT transferring the full heat to the burner flue. Doug
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
