sealevel_ram
Jun 05, 2015Explorer
MrWizard wrote:
i would suspect a bad 120v heater element leaking to ground aka the metal tube of the heater
you can turn off the ems, or you can pull out the heater element and test it for resistance between the shell/case and the power leads
it should read infinity on the ohms scale any lower reading and its defective
Wouldn't it be bad under generator power also?
