patperry2766 wrote:
OK...but what I do know is that there was a part missing that prevented my fridge from working properly on LP, but it worked fine on electricity. It was a little plastic valve that snapped to the end of a tube.
Paying rv repairman and having a missing part installed created a 'Placebo affect'.
That plug in hose is a bug screen that goes on end of drip pan drain hose. The drip pan is under the cooling fins in food compartment.
Whether on electric or gas wouldn't matter as the fins/drip pan/drain hose and bug screen would not affect one heat source without affecting the other.
Same as thermistor (sensor in clip on fin).....affects both heating sources.
