patperry2766 wrote:
OK...but what I do know is that there was a part missing that prevented my fridge from working properly on LP, but it worked fine on electricity. It was a little plastic valve that snapped to the end of a tube.
The ONLY way that would affect LP operation is IF the water was draining onto the LP burner area and disrupting the flame. Now, to the larger point. You stated "Electric works off a different system". Now, you had a condensation drain tube end cap installed and NOW, you state from THAT, that it is a different system???????? Doug
