dougrainer
Mar 07, 2014Nomad
Check is ONLY if it does not light on LP. There is no indication of a 120 control problem. Other than no cool. If your line voltage drops below about 104 volts it will go to LP but continue cooling correctly. If the line voltage is between 104 and 110, the heat element will not be as hot as it should be. Low line voltage will cause a Heat Element to not heat to its full potential. Heat Elements either work or do not. Have you checked your 120 voltage when this happens? Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
