Old-Biscuit
Mar 07, 2014Explorer III
Check light will only come on if gas fails....nothing to do with electric failing.
5A fuse on lower board is for electric heating element.
Electric heating element could be bad (unplugged and tested at leads....S/B 44 ohms)
Check 110V AC power at outlet fridge is plugged into
Check for AC power at lower circuit board
J5----AC line voltage (Black)
J6----AC neutral line (White)
J7----AC neutral out to AC heater
J8----AC line out to AC heater Switched side
Could be bad AC circuit, bad connection on plug(s) outlet and on board, could be bad lower board
Testing for AC power and where it isn't will ID probem vs just throwing parts at it
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
