wa8yxm
Mar 07, 2014Explorer III
WOrks fine on Gas, not on electric.
4 suspects in physical order
1: No electric (breaker, wiring fault, check using test lamp (Drop lamp or trouble lamp) at outlet in outside compartment
2: No electric (Plug fell out of socket, see 1)
3: Bad control board. Not closign 120 volt relay or bad relay
4: Bad heat element or wires to heat element bad (Suspect #1 by the way).
To test.
Start by unplugging the 120 volt plug and plugging in a test lamp.. LIGHT good, dark bad
Now using test leads and some care and caution DO NOT TOUCH EXPOSED METAL
attach clip leads to the heat element leads Either end is ok, the other end of the clip leads goes to teh test lamp.. INSULATE THE PLUG (I like to shove it in a plastic container with lid) and plug the unit back in, Switch to AC and see if the light, lights (NOTE Fridge must be warm enough to turn on) If light lights, ti's the heat element, if fridge hits 45 degrees with T-Stat set to coldest and light is NOT on, it is the control board
Dinosaur boards are best.
To test.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
