34 amps @ nominally 12 volts. Mine operated just fine on a 35 amp PD converter with wizard. It was not a "planned" test, but rather happened by accident.
The alternator doesn't seem to power the fridge well at all in 12 volt mode.
dougrainer wrote:
2. Even if you have a 3 way refer, operating on 12 volts is ONLY for when the unit is in Transit and your Chassis engine Alternator is supplying the needed voltage/amps to power the 12 volt element. It is NOT designed to operate on a Power Converter, as it takes a lot of power to run that 12 volt element.
