pianotuna wrote:
34 amps @ nominally 12 volts. Mine operated just fine on a 35 amp PD converter with wizard. It was not a "planned" test, but rather happened by accident.
The alternator doesn't seem to power the fridge well at all in 12 volt mode.
dougrainer wrote:
2. Even if you have a 3 way refer, operating on 12 volts is ONLY for when the unit is in Transit and your Chassis engine Alternator is supplying the needed voltage/amps to power the 12 volt element. It is NOT designed to operate on a Power Converter, as it takes a lot of power to run that 12 volt element.
I should have clarified. 4 Cubic Foot and smaller RV refers will usually operate fine on 12 volts. 6CF and larger are NOT designed to run on 12 volts unless the Truck Alternator is engaged. 6 CF and larger, the 12 volt element is a MAINTAINER, not a cooling mode Heat element. Using a Inverter/Charger or a Power Converter to run a 6CF and larger on 12 volts is foolish and a detriment to a Power Converter. Why put the strain on those chargers when you can operate on 120 or LP? Doug
