BFL13 wrote:
I think I got that this time!  Have you a link to such a relay with illustrations for the terminals you describe--"common", N.O. pins, etc?  Thanks!
I have ordered a 120v element but it is 325w instead of 300w in hopes I can make it work from the 120v output from the board.  The specs for the 300 and 325 in amps and ohms are not much different.
The 120V option will be your best bet.  If you still want to try the relay hack, Google for lighting relay diagrams since they’re basically doing something similar.
On automotive style relays, pin 85 and 86 are the coil , 30 is common and 87 is normally open.
https://www.the12volt.com/relays/spdt-and-spst-automotive-relays.asp
