MalibuDave42
Oct 19, 2020Explorer
Back home, food out of the fridge, time to run the thermistor test.
Old-Biscuit says "Unplug the thermistor leads from lower circuit board (P2 connector at J3 --- S/B white leads)"
Not sure what "P2 connector" means, but at J3 on the lower board there is 1 connector with a white-shielded wire with 2 conductors inside. This 2 conductor wire runs up the back of the fridge and disappears.
I turned off the power, pulled the wire from the connector. Turned on the power, turned on the fridge. The fridge is reporting a "thermistor has an error" error code. (must be the right wire)
Unfortunately, the fridge will not start on propane nor 120v with this error code.
What should I do? I apparently can't run this test.
