GDS-3950BH
Oct 20, 2020Explorer
MalibuDave42 wrote:
My clip-the-tip still has not arrived. ?? I've been using the fridge as is. It's limping along. Fridge temp goes to the low 30's then sails into the mood to high 40's. What are your thoughts on this temperature pattern:
Where are you and what are the nighttime ambient temps outside? Once they're below 45 and dropping an absorption fridges efficiency drops almost exponentially because it can not generate enough heat. Try putting an incandescent light bulb, preferably 100 watt, in a socket in the lower compartment or block off the lower vent openings one at a time to see if the interior temp drops.
