MalibuDave42
Oct 20, 2020Explorer
Yes, nighttime temps in the 20's to lower 30's.
I did a bit of internet digging after you posted about ambient temps. The issues range from "no problems to -20C" to "I had issues around 40F." Thinking about the physics side of this problem, it makes a great deal of sense ambient temperature affects operation. One possible conclusion of the variable results I see posted to the internet is installation matters - aka the airflow of a given install affects the operational temperature.
100 watt bulb sounds nice, but a no-op for no-shore-power use. Blocking off lower vent openings is worth a try. Thanks for the tip.
