Better verify the fans are running. Another issue that can occur is low gas pressure.
In the past 4 years I've been blessed with 2 bad fans one old one new and 3 bad pressure regulators one old and 2 new.
The first replacement fan ran when installed and had failed before we got to our destination 12 hours later. Replaced it again it's been working now maybe 2 years.
The first new regulator was bad when I put it on the camper with max adjustable pressure at 8" WC. The second new one lasted about a year.
All of the above created refrigerator cooling issues for me.
Not sure if Dometic has a similar operating cycle, Norcold does, but another issue that occurs that isn't an actual problem is a defrost cycle that allows the frig to melt any accumulated ice on the cooling fins.
You may also want to pull the frig and clean the burner. This may be indicated if the unit works good on AC but not as well on gas.
Good luck,
