SDcampowneroperator wrote:
The outside compartment is too cold. Turn off the outside fans, even block some of the vents to raise the temp. there into the 50's to low 100's . Then the absorption cooling will work.
A shopping or garbage bag stretched behind the lower grille with it to hold the bag should do it. In extreme cold, like 10 below F,and colder, close off the upper grille as well.
His outside temps are NOT to low. NEVER block off air flow access in low temps. Use a 60 watt light bulb to heat up the rear, but NEVER block off air flow. If BELOW 20 degrees ambient, the RV refer will NOT operate correctly regardless of what you do. Doug
