red31
Jul 19, 2020Explorer
Shibre,
the parts lists doc shows the 120vAC specs on page 2
RM4223 parts list
Measure the temp as directed!
taller chimneys work better than shorter.
Check the install manual you posted, esp the minimum measurements on the back. Adding a baffle between the upper and lower vents may be need to help the convection move over the upper fins. Lots of folks have added baffling @ https://www.popupportal.com/forums/refrigerators-and-coolers.78/ , directing air to the upper fins and adding a 12v fan can help these fridges as they do not come with them generally in PUs.
RM4223 parts list
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
