jetcare
Jan 09, 2017Explorer
Complete the 24 hour electric test of the cooling unit. Remove the two wires from the circuit board that run to the electric heating element. Make a 120VAC jumper that plugs into the 120VAC outlet and connect to the two heating element wires. Be careful not to shock yourself. This bypasses all your controls. Put a glass of water in the lower section of the refrigerator. After 24 hours of operation, the freezer should be 0 degrees F and the water should be 35-38 degrees. If not, the cooling unit is bad.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
