pianotuna
Jan 09, 2017Nomad III
Hi,
It did actually work for a member here called "BobsYourUncle". He operated his fridge when it was extremely cold outside. This happened two years ago in Calgary.
DownTheAvenue wrote:pianotuna wrote:
While you were away the coolant gelled from the low temperatures. If you are lucky resetting the high limit may work--but the gelling may have caused an overheating situation and caused a block in the tubing. Sometimes the blockage can be dislodged by taking the fridge out and tipping it upside down (please use violence, rolling it over several many times). I hope you get it working again soon.
This is an old wive's tale. If the chemicals have hardened in the tubing, they have gone through a chemical reaction, and no amount of tipping, burping, beating, or anything else will restore it.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
