dougrainer
Feb 10, 2015Nomad
The heat build up from the sun is minor compared to the heat generated by the LP burner. I have NEVER had or heard of a heat issue causing a Control board malfunction on a refer. When this happens again, fire up the refer on LP and immediately lite the stove top burners(all 3 or 4). See if the stove top burners either do not all light or the flame is very low. I would suspect heat causing the LP regulator to malfunction. You DO have clear unobstructed ventilation all the way up the refer roof top vent? Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
