RJsfishin
Feb 10, 2015Explorer
I'm near positive its not a propane problem, but I'll check the stove. If that is still burning right on flameout, I'm thinking I should watch the voltage on the gas valve when it flames out.
Thanks Doug
Thanks Doug
dougrainer wrote:
The heat build up from the sun is minor compared to the heat generated by the LP burner. I have NEVER had or heard of a heat issue causing a Control board malfunction on a refer. When this happens again, fire up the refer on LP and immediately lite the stove top burners(all 3 or 4). See if the stove top burners either do not all light or the flame is very low. I would suspect heat causing the LP regulator to malfunction. You DO have clear unobstructed ventilation all the way up the refer roof top vent? Doug
Having RV issues? Connect with others who have been in your shoes.24,377 PostsLatest Activity: Apr 11, 2026
