newman_fulltime
Feb 10, 2015Explorer II
dougrainer wrote:doug my fault imeant voltage drop is what he is experiancingnewman fulltimer wrote:
If in a hot climant running the ac its pulling alot of amprage your converter or basttery is not keeping up for the smount needed. Once the temp cools of the demand goes down voltage goes up and fridge comes on.
Check wiring connectoins for corrosion and tightness battery for proper voltage
I want you to read your post again and think about what you stated.
1. The Roof AC is pulling AC amps
2. The refer is on LP and the 12 volt controls pull milliamps
3. The Converter only supplies 12 volt current to the RV and would NOT be affected by the Roof AC 120 volt amp draw.
4. Remember , he is on LP on the refer not 120 and even if he was on 120 on the refer, the amps would be 2.6 and the refer would not throw a LP code(F). Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
