Fishinghat
Feb 10, 2015Explorer II
From your description, it appears your frig's cooler coils are overheating. I'd suggest installing several small computer type fans to the inside of the lower vent cover, using nylon ties. Connect the fans to a switch and to the 12 volt supply. You can turn the fans on during the day and off at night.
You could also install two of the larger fans on top of your cooling coils on the back of the frig and connect them to a thermal couple to automatically turn the fans on and off. This would require removing the frig into the coach to access the coils on the top. However, many newer coaches have these fans installed during assembly, and it probably would be the preferred method for you or others updating their coaches.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
