Canadian_Rainbi
Feb 10, 2015Explorer
Is your fridge in a slide and vented out the side instead of the roof? If so it has 2 fans blowing air up to the cooler behind the top vent.
Are those fans running?
There is a thermistor that turns the fans on, located behind the top vent on the cooler fins.
It could be a thermistor problem, a fan problem (though there are two) OR, in the case that Dougrainer diagnosed for us (Once I listened to his advice :S ) a corroded connection that acted like the thermistor was bad.
I'm thinking that perhaps the cooler is working without the fans (or perhaps with just one fan) until the ambient temp up at the top gets too high. A degree or two could make a difference.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
