RJsfishin
Feb 10, 2015Explorer
This is a normal updraft thru the roof vent, no fans anywhere,.....until today,....I installed one 4" at the bottom of the vent cover. Then, a catastrophic event happened. I had the fan running, and was tightening the last screw, when my screwdriver slipped, went into the fan,....2 blades gone instantly, and very out of balance !!!!@#$%^
Back to the vendor for another fan, 4 bucks down the tubes !
New fan working perfectly, except I picked up the 12 volts off the gas valve, so the fan only runs when the fire is lit. I mite have to change that. The good news is, no F code all day. Bad news, the sun was not as hot as it has been the last 3 days, so while I mite have improved the situation, I won't know till it gets hotter here.
No, no low voltage problems,....14.6 at the gas valve when burning.
Thanks for all the ideas.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
