j-d
Feb 11, 2015Explorer II
I use two 92mm fans. Most recently from CompUSA/Tiger Direct $6 each, then I found this WalMart Four-Pack for $6
Here's the Link
Yeah they're cheap, not Ball Bearing, yada yada. Still they run 3-4 seasons including lots of salt air near the beach. The wiring corrodes off the board before the bearings fail.
I was glad to go 92mm. I ZipTie two side by side and the "assembly" lodges into a spot in the coils with no further mounting. Got a PC Power Supply Cable from RatShack and spliced into the fridge's power wiring. Fans plug together and plug into that Cable.
Here's the Link
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
