SoundGuy
Oct 09, 2018Explorer
riven1950 wrote:
I can tell you that my Dometic running on lp was killing a battery ( down to 12.0 volts ) every 24 hours when I had it parked in Jax Florida when we were evacuated from Florence. We were not staying in it and I pulled the fuse for the monitors so it was the only draw, at least that I could think of.
SoundGuy wrote:
Unless you also turned off or disconnected the fridge climate control heating element no wonder your batt was drawn down in just 24 hrs. :R
Did you? :@
BFL13 wrote:
The OP's Norcold doesn't even have one of those, so who cares? It will still want about 15AH a day as previously explained, based on actual measurements.
My post was clearly directed at riven1950 who has a Dometic fridge which well could have a climate control heating element. :S
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
