schlep1967
Oct 13, 2020Nomad
unbob wrote:
No, not broken. It's a Dometic fridge - the latches are a "flexi" plastic thingy. It's for sure not a positive metal locking latch. Weird thing is that when I pull on the door (with the latch engaged) it won't open - seems to hold the door closed really well.
So it latches well when sitting still but comes unlatched when moving. First thoughts are the fridge is flexing enough to spring the latch. The door shim idea above may work but if you are getting that much flexing they may just fall out.
Maybe try some 3M Dual lock strips. Cut one in half and put half on the frame and half on the door. Then put a whole one connecting the two across the gap for travel. If it doesn't work a little heat from a blow dryer will get them right off.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
