StirCrazy
Oct 14, 2020Moderator
I had a simular issue but in my fiver, the pins in the door hinges have plastic bushings over them, when they wear down they allow movment of the door and the dometic plastic door catches cant handle the extra movment and let the door open. if it gets bad enough you will find your door right off and on the floor eventualy. its a simple fix to put new bushings on the pins and you can test it by opening your doors and lifting up and down on them and seeing if there is a bit of movment.
Steve
Steve
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
