- subcamperExplorer IITo convert degrees to something more visual, a good indicator is inches-per-foot.
3 degrees = 5/8" per foot
6 degrees = 1 1/4" per foot
If you use a 2 foot level, one end would be 1 1/4" higher or lower for 3 degrees, and 2 1/2" higher or lower than the other.
Most fridges are mounted so front-to-back on the fridge is the width of the trailer. So an 8 foot wide trailer would need to be 10" off level to equal 6 degrees front-to-back on the fridge.
For a 30 foot trailer, it would need to be about 18 3/4" out of level from front to back to equal 3 degrees.
Steve - LwiddisNavigatorI believe in turning the fridge off too, Mr. Wizard, when parked for a short time and not level.
- MrWizardModeratorwhen i park off level at the street curb by grocery
i just turn the fridge off, while i'm there
most camping spots are not too bad
but street parking while shopping or sight seeing, well some places have domed streets, and pretty deep curbs - pasusanExplorer
dougrainer wrote:
3 degrees side to side is not really that drastic. We don't get our B as level as we do our trailer since it's harder with 4 wheels and our last trip we were just under 3 degrees front to back with the B which is side to side for the fridge. It was livable for us and we hope the fridge made it through OK.camperdave wrote:
Old-Biscuit wrote:
Norcold states degrees
3* side to side
6* front to rear
wow, that's a LOT of unlevel. Have we been overly worried about fridge level this whole time?
It SEEMS to be a drastic measurement. But, if you really look at 3 degrees and 6 degrees, it is not that far out of level. Doug - LwiddisNavigatorNew fridges are expensive as piano indicates.
- wa8yxmExplorer III3 degrees and both NOTE. it does make a difference if we are talking nose to tail or side to side.. As I recall one of 'em is more than 3. but 3 is safe.
So how much is 3 Degrees.????? Well figuring 8 feet side to side. a bit more than 5" or about 4.5 to 5 " at the wheels. You won't be comfortable at that pitch. I might. but Well. long story. - RJsfishinExplorerI can assure you, if you are so un level as to hurt the fridge, you will go looking for some blocks if you don't have jacks. And I didn't just start camping yesterday !
camperdave wrote:
3* side to side
6* front to rear
It SEEMS to be a drastic measurement. But, if you really look at 3 degrees and 6 degrees, it is not that far out of level. Doug- DrewEExplorer III
camperdave wrote:
3* side to side
6* front to rear
Indeed, many people are unnecessarily cautious about leveling their fridge. Other people are insufficiently cautious, of course.
In practice, if the RV is pretty close to level, as in level enough for you to do normal things comfortably and operate the others systems reasonably (things like fry an egg or take a shower or walk around without going bonk into the cabinets), it's more than level enough for the fridge. - pianotunaNomad IIIIt is better to be cautious than to have to cough up for a new Fridge.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
