TurnThePage
Nov 02, 2021Explorer
Tank heaters are pretty standardized. Just a pad glued to the tank, and a thermostat. You add your own on/off switch.
I went with the Ultraheat mentioned above because they were AC/DC. When I was plugged into shore power, all I had to do was flip a breaker. They were much higher quality compared to the other offerings at the time of my install, which was 2004. Other heat pads were foil, Ultraheat were a rubber mat with better glue.
I also added a 12v only heat rope wrapped around the tank drains near the gate valves.
Dunno if this was helpful or not. JMHO
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
