bighatnohorse
Nov 11, 2015Explorer II
Hopefully you haven't sprayed anything into the lock.
Graphite is the appropriate lube for sticking locks.
Most auto shops or Ace Hardware will have it. You want a small tube with a small tip. Hold the tip against the lock opening, pry the little cover to the side if needed, and give the tube a squeeze or two.
Put a little graphite on the key and attempt to insert it. Try again if it doesn't work the first time.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
