SoundGuy
Nov 13, 2015Explorer
2112 wrote:
Out of your own admission you will not be able to use your alternate entrance without finding a small child but go ahead and knock yourself out.
Incorrect, I never said that ... rather, I'm suggesting that if one found it difficult to lift the bed platform (with the weight of the mattress obviously bearing down on it) from inside the storage area below then crawling through cabinet doors that many install on the end of the bed platform for convenience of access could be an option. I'll try it in the spring myself when I mod that storage compartment panel in my own trailer so it can be quickly removed from the pass through side but I have little doubt I will be able to elevate the bed platform with no difficulty at all. It's unfortunate that you can't just agree to disagree but rather find it necessary to be offensive in your comments just because you see this a different way ... so typical. :(
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
