Nov 13, 2015Explorer II
2112 wrote:
Out of your own admission you will not be able to use your alternate entrance without finding a small child but go ahead and knock yourself out.
SoundGuy wrote:
Incorrect, I never said that ...
SoundGuy wrote:So I'm to believe someone else wrote this?
I doubt I could squeeze through one of those openings but a 10 yr old sure would, at which point that same 10 yr old could remove the screws securing the entry door lock. Considering this is such an easy and obvious solution for most to gain entry into their travel trailer in a case where the entry door lock may have failed there's not a chance I'd ever consider taking a Dremel tool or pry or anything else to the door lock. :E
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
