- 2112Explorer II
SoundGuy wrote:
With all due respect replacing a door is simple. You're advocating cutting out bed supports. Are you kidding :h2112 wrote:
I was in a state park a few years ago when one of our fellow campers was cutting away at his lock assembly with a Dremel tool using a cut off blade. I assume another victim of FIC. He got the door open by cutting up the assembly but I do not know the details.
Might be something to try.
JMO, but I wouldn't go anywhere near this with any high speed tool - one inadvertent slip and you could be replacing the entire door. :M Instead, go through where any damage will be minimal, easy repairable, and invisible once corrected - the front pass through storage compartment. - Hornnumb2ExplorerDo the screwdriver trick thats the easiest. Just use a flat head screwdriver that has a square shaft, tap it in and use a wrench on the shaft to unlock it.
- pawpaw47ExplorerCan you get in through one on the baggage compartments?
- rbp111ExplorerI was locked out of my trailer once and had to call a locksmith. After working on the lock for about 1/2 an hour he called his boss and told him the only option was to drill. His boss told him emphatically NO.
So he tried again.. And this time he squirted a lubricant in the lock hole, placed the key in the lock and gently, but firmly tapped the key in. Then he turned the key, and voila, it opened! - SoundGuyExplorer
JMO, but I wouldn't go anywhere near this with any high speed tool - one inadvertent slip and you could be replacing the entire door. :M Instead, go through where any damage will be minimal, easy repairable, and invisible once corrected - the front pass through storage compartment. - 2112Explorer III was in a state park a few years ago when one of our fellow campers was cutting away at his lock assembly with a Dremel tool using a cut off blade. I assume another victim of FIC. He got the door open by cutting up the assembly but I do not know the details.
Might be something to try. - SoundGuyExplorer
icanon wrote:
If windows are 'locked' you can try the storage compartment and thru the bed to get in?
Do I hear an echo? :R - icanonExplorerIf windows are 'locked' you can try the storage compartment and thru the bed to get in?
- HalmfamilyExplorerWhen ours broke last year Trimark said to take a flat head screwdriver and tap it into the lock with a hammer and turn it to open. I didn't try it as I was able to go through my back door and crawl over the kitchen island to get to the front door and dismantled the lock from the inside.
The locks are easy to replace and as others have said a POS. Good luck - SoundGuyExplorer
joelyn wrote:
Any idea as to what happened and what I can do to fix it?
This has nothing to do with lock lubrication nor is it necessary to employ the costly services of a locksmith or to take extreme measures such as drilling out the lock assembly yourself. All you need is an alternate point of entry into the trailer ... unfortunately you've neglected to provide pertinent information as to your make, model, year of camper or the type of lock it may have, as should be indicated on the key itself but this sure sounds like a classic Fastec lock failure as fully described in this FIC Lock Recall.
Assuming you have a conventional travel trailer with a front queen bed it will also have a front pass through storage compartment - i.e. your alternate point of entry. You'll have to remove some paneling, perhaps cut a bed support or two, but doing so will get you inside the bed platform where you can then either lift the hinged platform to gain entry to the trailer itself or if necessary cut out some bed platform paneling, all of which can be easily repaired later. If you're too big to fit it's time to conscript a neighbourhood kid for the task. :D Once inside, remove the four screws securing the lock to the door, remove it, and replace it with a new one. If it is indeed an FIC lock Fastec will replace it at no charge but I suspect you won't want to wait the weeks or months this may take so it would be quicker to just pay for the replacement lock yourself.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
