Greytd
Jul 16, 2013Explorer
Chances are either the shear pin is broken or the top gear is stripped or has a broken tooth. You can realign them by removing the bolt in the cross bar and manually rotate one jack or the either other until they are even again. you will need to get the top of the jacks checked out.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
