GordonThree wrote:
I think it's safe to assume your fridge has one, and it's always on.
'tiredTeacher wrote:
You are correct! I called the Dometic folks, was put on hold for about 5 min. while the tech rep researched the issue and was told it is always on. When it warms up a bit, I'll see if the wire is accessible at the light switch. The climate control and interior light are on the same circuit.
There's no "if" about it ... as shown in my pics all you need to do is cut the thicker red wire at the fridge light switch and insert a SPST switch in the line - done. :B
