JaxDad
May 16, 2020Explorer III
Why make it more complicated (and expensive) than it needs to be?
Run PEX pipe from a disconnect in the basement with a sediment drain and ball valve. When you’re finished with the water each fall just shut off the supply and open both spigots, the water drains back and anything left won’t matter, PEX will freeze thaw no problem even if it didn’t completely drain.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
