westend
Sep 24, 2014Explorer
Those Frost King heat cables put out a lot of heat. I install them for folks up here in MN who have gutter and roof problems with icing. I have one I use in one gutter here, at home. A 60' Frost king cable can melt a frozen 4" gutter of ice in a few hours at 0f.
I wouldn't use one on a plastic water hose. They make thermostatically controlled heat tapes for small pies that would be a better choice. Enclosing the heat tape is sometimes desirable like in well pits and outdoor locations. You'd have to check the instructions. In GA, I'd think wrapping the hose with a good amount of insulation would work for occasional overnight low temps. You could also disconnect the hose and drain it, operating off your onboard tank for the few nights that are below freezing.
